Ir para o conteúdo principal
Battery disassembly
  1. Battery disassembly, Remove the battery: passo 1, imagem 1 %32 Battery disassembly, Remove the battery: passo 1, imagem 2 %32 Battery disassembly, Remove the battery: passo 1, imagem 3 %32
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
    Pergunte ao FixBot
Conclusão
Roberto Bartolacci
Membro desde: 02/10/18
1.548 Reputação
Autoria de 9 guias
1Comentário do guia
Maybe rename this guide "laptop battery removal" seeing as no dissasembling is taking place.
sephiroth_dk - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 50
Ao todo: 712
