Introdução
This will show how to replace the battery in case it doe no longer hold a charge or as other power issues
O que você precisa
Use plastic opening tools to pry open the case starting on the long side. The cover has a total of 8 clips, 4 of which (located on the long sides) are designed so they will be damaged when the device is opened.
After prying open 3 sides of the cover, it is still attached to the aluminium cover by double-sided adhesive tape. Use a screwdriver to create a small gap and use the scalpel to cut the adhesive. Alternatively you can losen the adhesive with a heat gun.
After loosening the adhesive, the case cover can be easily removed.
Remove any adhesive residue from the battery cover and the housing cover with a scalpel / rubbing alcohol.
Then carefully disconnect the battery flex cable, ensuring that the contacts are not being short-circuited.
The battery is adhered to the housing, it takes some force to remove it. Avoid puncturing of the battery as it could catch fire and/or explode! Dispose of the old battery properly.
The new battery can be fastened through the remaining adhesive residue. Reconnect the flex cable of the new battery, making sure that the contacts are not short-circuited.
The display should indicate a empty battery.
Before further assembly, the battery should be fully charged and it should be checked whether the device terminates the charging process when the battery is fully charged. If this is not the case, the new battery could be destroyed by the device.
Monitor the initial charge and carry it out in a place where there are no flammable objects.
Secure the battery cover with the two TX 5 screws. Ensure a good fit of the back cover with a few strips of double-sided tape. Limit the amount of tape so as not to hinder future disassembly.
The rear cover will still fit well and tight despite the four missing fastenings.
13 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
2 comentários
Es sollte m.E. noch ergänzt werden, dass der Deckel an den schmalen Seiten mit je zwei Laschen gesteckt ist. Um den Deckel zu lösen, muss man, nachdem die langen Seiten wie beschrieben geöffnet wurden, ihn etwas nach außen wölben: Man zieht dazu die schmalen Seiten in Richtung der Gehäusemitte, so dass man die Laschen herausziehen kann.
By far the worst part is the battery cover is welded to the back of the case with gluonium which cannot be removed with anythhng but gamma rays and kryptonite, so as the guide says,, long thin knife is what you need. The battery is glued in the same but you don’t care so much at this point :-) See step 3, the tabs top and bottom, you remove the cover by flexing it away from the frame at about the mid point.
Time and patience, gently, gently teasy monkey…
You skip how to open the 3rd side, and if the third side to open should be the top or bottom.
Aporatael - Responder
515-1058-01 (part #) MC-26536 (model #) for the Kindle 4/5 battery. I got mine from Amazon - came with tool to crack lid.
ElvinC - Responder
It is suggested in the overall guide comments that one could unclip all four side tabs and pry up from the middle of the left or right sides to get the two tabs from either the bottom or top out so that you can slide the cover off.
ElvinC - Responder
