Ir para o conteúdo principal
Battery Disconnect
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Battery Disconnect, Unfasten the lower case: passo 1, imagem 1 %32 Battery Disconnect, Unfasten the lower case: passo 1, imagem 2 %32
    • If your device has a nano‑SIM card tray on the back edge, remove it before starting your repair.
    • Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
  2. Battery Disconnect, Insert an opening pick: passo 2, imagem 1 %32 Battery Disconnect, Insert an opening pick: passo 2, imagem 2 %32
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Battery Disconnect, Release the front clips: passo 3, imagem 1 %32 Battery Disconnect, Release the front clips: passo 3, imagem 2 %32 Battery Disconnect, Release the front clips: passo 3, imagem 3 %32
    • Angle the pick down at about 30 degrees.
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Battery Disconnect, Release the USB clip: passo 4, imagem 1 %32 Battery Disconnect, Release the USB clip: passo 4, imagem 2 %32
    • Insert an opening tool between the lower case and the chassis, just to the right of the USB port on the left edge.
    • Pry the opening case up to release the clip next to the USB port.
    • It may take significant force and multiple attempts to release the clip. You will hear a popping noise when the clip releases.
  5. Battery Disconnect: passo 5, imagem 1 %32 Battery Disconnect: passo 5, imagem 2 %32
    • Insert an opening pick on the left edge above the USB port. Slide the pick all the way up to the ethernet port to release the clips.
  6. Battery Disconnect: passo 6, imagem 1 %32 Battery Disconnect: passo 6, imagem 2 %32
    • Insert an opening pick on the right edge near the corner.
    • Slide the pick along the right edge all the way to the HDMI port to release the rest of the clips.
  7. Battery Disconnect: passo 7, imagem 1 %32 Battery Disconnect: passo 7, imagem 2 %32 Battery Disconnect: passo 7, imagem 3 %32
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  8. Battery Disconnect, Disconnect the battery: passo 8, imagem 1 %32 Battery Disconnect, Disconnect the battery: passo 8, imagem 2 %32 Battery Disconnect, Disconnect the battery: passo 8, imagem 3 %32
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
Conclusão
Spencer Day
Membro desde: 09/14/22
155.872 Reputação
Autoria de 1.033 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.828 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 56
