Ir para o conteúdo principal
Battery Disconnect
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Battery Disconnect, Unfasten the lower case: passo 1, imagem 1 %32 Battery Disconnect, Unfasten the lower case: passo 1, imagem 2 %32 Battery Disconnect, Unfasten the lower case: passo 1, imagem 3 %32
    • Remove the 14 Phillips screws securing the lower case:
    • Seven 8.8 mm screws
    • Seven 10.1 mm screws
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. Battery Disconnect, Insert an opening pick: passo 2, imagem 1 %32 Battery Disconnect, Insert an opening pick: passo 2, imagem 2 %32
    • Insert an opening pick between the lower case and the chassis on the front right edge near the captive screw.
  3. Battery Disconnect, Release the clips: passo 3, imagem 1 %32 Battery Disconnect, Release the clips: passo 3, imagem 2 %32 Battery Disconnect, Release the clips: passo 3, imagem 3 %32
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Repeat this process along the perimeter of the lower case to release the remaining clips.
  4. Battery Disconnect, Remove the lower case: passo 4, imagem 1 %32 Battery Disconnect, Remove the lower case: passo 4, imagem 2 %32 Battery Disconnect, Remove the lower case: passo 4, imagem 3 %32
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. Battery Disconnect, Reposition the tape: passo 5, imagem 1 %32 Battery Disconnect, Reposition the tape: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers or your fingers to peel back the tape on the battery connector.
  6. Battery Disconnect, Disconnect the locking bar: passo 6, imagem 1 %32 Battery Disconnect, Disconnect the locking bar: passo 6, imagem 2 %32
    • Use the flat end of a spudger to gently push the locking bar away from the battery connector.
    • Make sure the locking bar is not covering the battery connector, or you may damage the battery connector's socket in the next step.
  7. Battery Disconnect, Disconnect the battery: passo 7, imagem 1 %32 Battery Disconnect, Disconnect the battery: passo 7, imagem 2 %32 Battery Disconnect, Disconnect the battery: passo 7, imagem 3 %32
    • Insert the pointed end of a spudger under the battery connector.
    • Pry under the left edge of the battery connector to disconnect the left side of the connector.
    • Repeat this procedure for the right side of the connector.
Conclusão
Spencer Day
Membro desde: 09/14/22
155.719 Reputação
Autoria de 1.033 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.821 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 63
