Introdução
prereq battery disconnect
O que você precisa
Before you begin, switch off your phone.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
