Ir para o conteúdo principal
Batteries in Nikon Coolpix 4600 Replacement
O que você precisa
  1. Batteries in Nikon Coolpix 4600 Replacement, Batteries: passo 1, imagem 1 %32
    • Locate the battery compartment on the bottom right of the camera.
  2. Batteries in Nikon Coolpix 4600 Replacement: passo 2, imagem 1 %32 Batteries in Nikon Coolpix 4600 Replacement: passo 2, imagem 2 %32
    • While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open.
    • If the door does not pop open, gently lift the door using your finger.
  3. Batteries in Nikon Coolpix 4600 Replacement: passo 3, imagem 1 %32
    • Remove the dead batteries. The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out. If this does not work, you can simply pull them out.
  4. Batteries in Nikon Coolpix 4600 Replacement: passo 4, imagem 1 %32
    • Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Close the battery door.
    • Remember to slide the switch back into the lock position.
Conclusão
Reassembly of the camera is the final step in the guide.
Richard
Membro desde: 04/19/12
9 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 9-43, Regan Spring 2012 Membro de Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 75
Duração total: 3,041
