Ir para o conteúdo principal
Bathroom Drawer Slide Replacement
O que você precisa
  1. Bathroom Drawer Slide Replacement, Slide Replacement: passo 1, imagem 1 %32 Bathroom Drawer Slide Replacement, Slide Replacement: passo 1, imagem 2 %32
    • Before starting, remove the existing sliders and brackets by unscrewing the screws in a counterclockwise direction.
  2. Bathroom Drawer Slide Replacement: passo 2, imagem 1 %32
    • Measurements are crucial to starting when inserting a new drawer slide replacement.
    • Be sure to measure the inside of the drawer with a measuring tape to see its distance on how long the drawer slide must be.
  3. Bathroom Drawer Slide Replacement: passo 3, imagem 1 %32
    • Another critical measurement is the width of which the drawer must be fit. Make sure your measurements are correct with the width needed for the drawer.
  4. Bathroom Drawer Slide Replacement: passo 4, imagem 1 %32
    • Now it is time to insert the drawer insert inside; ensure that the holes align with the insert, and be very cautious with the screw and screwdriver.
  5. Bathroom Drawer Slide Replacement: passo 5, imagem 1 %32
    • This step requires your screwdriver, which is needed to insert the screw into the hole when inserting the drawer slide. Ensure the screw is tight and secure before inserting it into the drawer wall.
  6. Bathroom Drawer Slide Replacement: passo 6, imagem 1 %32
    • As soon as the correct measurements and screw are inserted into the drawer slide, it is time to insert the drawer slide with the screw.
    • Be very cautious, and do not rush this step. Turn the screwdriver in a clockwise direction to tighten the screw.
  7. Bathroom Drawer Slide Replacement: passo 7, imagem 1 %32
    • Now that the drawer slide is inserted, it is time to insert the drawer slide supporter that is needed for the drawers not to get scratched and damaged. This step requires a screwdriver.
  8. Bathroom Drawer Slide Replacement: passo 8, imagem 1 %32
    • It is time to insert the drawer, be very cautious with this step, and be sure not to damage it. Insert it slowly by latching it upon the drawer slide and pushing forward for the drawer to slide in.
  9. Bathroom Drawer Slide Replacement: passo 9, imagem 1 %32
    • When the drawer is inside the drawer slide insert, use the clamps to secure the drawer, so the drawer will not latch out and fall out of the drawer slide.
  10. Bathroom Drawer Slide Replacement: passo 10, imagem 1 %32
    • As soon as all steps are complete, it is now time to push in your drawer; with no damage to the cabinets, the drawer will slide in easily.
Conclusão
Enjoy your new drawer!
Uma outra pessoa concluiu este guia.
Adam J Acosta
Membro desde: 08/22/22
181 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 182
