Introdução
This guide shows how to replace the LED screen. This is a more complicated guide because it involves removing the back plate of the watch along with the battery.
  1. Wedge a plastic opening tool between band contacts.
    • Wedge a plastic opening tool between band contacts.
  2. Push in plastic opening tool until the components click and pop out of the holder.
    • Push in plastic opening tool until the components click and pop out of the holder.
    • Repeat steps for other band.
  3. Remove four 4mm screws using a PH000 screwdriver.
    • Remove four 4mm screws using a PH000 screwdriver.
    • Remove back plate.
  4. Use tweezers to remove elastomeric, or zebra, connector.
    • Use tweezers to remove elastomeric, or zebra, connector.
  5. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  6. Use the flat end of the spudger to carefully lift the battery until adhesive seal is broken. Use the flat end of the spudger to carefully lift the battery until adhesive seal is broken.
    • Use the flat end of the spudger to carefully lift the battery until adhesive seal is broken.
  7. Use the pointy edge of the spudger tool to  detach battery leads from the circuit board.
    • Use the pointy edge of the spudger tool to detach battery leads from the circuit board.
  8. Use PH000 screw driver to remove two 6mm bracketed screws. Remove bracket.
    • Use PH000 screw driver to remove two 6mm bracketed screws.
    • Remove bracket.
  9. Use PH000 tool to remove two 4mm screws.
    • Use PH000 tool to remove two 4mm screws.
  10. Desolder the four connecting pins.
  11. Use spudger tool to lift the clasp of LED connector strip and remove from watch case.
    • Use spudger tool to lift the clasp of LED connector strip and remove from watch case.
  12. Use spudger tool to remove the LED screen from the watch case.
    • Use spudger tool to remove the LED screen from the watch case.
Conclusão
Kaitlyn Lee
518 reputação
4 Guides authored
Equipe
IUPUI, Team S6-G1, Baechle Fall 2017 Membro de IUPUI, Team S6-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G1
4 Membros
4 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Todo: 72
