Ir para o conteúdo principal
Barbie Doll Hair Replacement
O que você precisa
  1. Barbie Doll Hair Replacement, Barbie Doll Hair: passo 1, imagem 1 %32 Barbie Doll Hair Replacement, Barbie Doll Hair: passo 1, imagem 2 %32 Barbie Doll Hair Replacement, Barbie Doll Hair: passo 1, imagem 3 %32
    • Use light force to pull barbie head off of the body.
    • If stuck, soak in warm water to loosen.
  2. Barbie Doll Hair Replacement: passo 2, imagem 1 %32 Barbie Doll Hair Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Cut off all of the remaining hair using scissors.
    • Tweezers may be used once hair is too short for scissors.
    • It is important to remove as much hair as possible.
  3. Barbie Doll Hair Replacement: passo 3, imagem 1 %32 Barbie Doll Hair Replacement: passo 3, imagem 2 %32 Barbie Doll Hair Replacement: passo 3, imagem 3 %32
    • Cut the yarn pieces for doll hair.
    • With a ruler, measure equal pieces twice as long as intended hair length.
    • Cut enough for desired hair thickness.
    • To make up for inconsistencies in length, you may cut pieces longer and trim later.
  4. Barbie Doll Hair Replacement: passo 4, imagem 1 %32 Barbie Doll Hair Replacement: passo 4, imagem 2 %32 Barbie Doll Hair Replacement: passo 4, imagem 3 %32
    • Thread yarn between the forked tip of the reroot tool.
    • Attempt to thread the yarn at its midpoint for more even hair.
    • Insert the reroot tool into a small hole atop the doll's head.
    • Push the yarn inside as far as the tool will allow.
    • Remove the reroot tool from the head, leaving the yarn tucked inside.
  5. Barbie Doll Hair Replacement: passo 5, imagem 1 %32
    • Add glue to the inside of the doll's head.
    • Plug in and preheat the glue gun.
    • Insert glue gun from the base of the head.
    • Add a thicker layer of glue for stronger hair.
    • Hot glue can cause burns when exposed directly to skin.
  6. Barbie Doll Hair Replacement: passo 6, imagem 1 %32
    • After applying glue, use the blunt end of the rerooting tool to spread glue to cover the inside of the head.
    • Do this immediately after applying glue, because it will dry quickly.
  7. Barbie Doll Hair Replacement: passo 7, imagem 1 %32 Barbie Doll Hair Replacement: passo 7, imagem 2 %32
    • Wait for the glue to dry (15-30 minutes).
    • Once the glue is dry, attach the Barbie head back onto the neck joint.
    • For extra styling and volume, you may separate yarn strands.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Miranda Comstock
Membro desde: 01/31/23
170 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-3, Andersen Winter 2023 Membro de UC Davis, Team 2-3, Andersen Winter 2023
UCD-ANDERSEN-W23S2G3
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 30
Últimos 30 dias: 96
Ao todo: 2,623
