Ir para o conteúdo principal
Backpack Strap Buckle Replacement
O que você precisa
  1. Backpack Strap Buckle Replacement, Strap Buckle: passo 1, imagem 1 %32 Backpack Strap Buckle Replacement, Strap Buckle: passo 1, imagem 2 %32
    • Use a seam ripper to rip out the thread.
    • The thread to be cut is the one that attaches the buckle to the strap. It's usually sewn to form an X on it.
  2. Backpack Strap Buckle Replacement: passo 2, imagem 1 %32 Backpack Strap Buckle Replacement: passo 2, imagem 2 %32 Backpack Strap Buckle Replacement: passo 2, imagem 3 %32
    • Pick up the strap buckle that was attached to the strap.
    • Take out the material from the old buckle.
  3. Backpack Strap Buckle Replacement: passo 3, imagem 1 %32 Backpack Strap Buckle Replacement: passo 3, imagem 2 %32 Backpack Strap Buckle Replacement: passo 3, imagem 3 %32
    • Place the material into the new buckle.
    • Look for the original spot which it was originally sewn and place it there.
  4. Backpack Strap Buckle Replacement: passo 4, imagem 1 %32 Backpack Strap Buckle Replacement: passo 4, imagem 2 %32 Backpack Strap Buckle Replacement: passo 4, imagem 3 %32
    • Use a needle and thread to sew the material linking strap and buckle to the bag.
    • Using a sewing machine if available would make this easier.
    • Sew along the "X" outline on material attached to the buckle.
  5. Backpack Strap Buckle Replacement: passo 5, imagem 1 %32 Backpack Strap Buckle Replacement: passo 5, imagem 2 %32 Backpack Strap Buckle Replacement: passo 5, imagem 3 %32
    • Finally place the strap length adjuster into the buckle.
Conclusão
3 outras pessoas executaram este guia.
Olajide Abatti
Membro desde: 10/31/17
167 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 70
Ao todo: 29,711
