Ir para o conteúdo principal
Backbone One Left Trigger Replacement
O que você precisa
  1. Backbone One Left Trigger Replacement, Unfasten the screws: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Left Trigger Replacement, Rotate the upper cover: passo 2, imagem 1 %32 Backbone One Left Trigger Replacement, Rotate the upper cover: passo 2, imagem 2 %32 Backbone One Left Trigger Replacement, Rotate the upper cover: passo 2, imagem 3 %32
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Left Trigger Replacement, Remove the protective tape: passo 3, imagem 1 %32 Backbone One Left Trigger Replacement, Remove the protective tape: passo 3, imagem 2 %32 Backbone One Left Trigger Replacement, Remove the protective tape: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Left Trigger Replacement, Open the ZIF connector: passo 4, imagem 1 %32 Backbone One Left Trigger Replacement, Open the ZIF connector: passo 4, imagem 2 %32
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Left Trigger Replacement, Disconnect the interconnect cable: passo 5, imagem 1 %32 Backbone One Left Trigger Replacement, Disconnect the interconnect cable: passo 5, imagem 2 %32
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Left Trigger Replacement: passo 6, imagem 1 %32 Backbone One Left Trigger Replacement: passo 6, imagem 2 %32
    • Remove the upper half of the left controller assembly.
  7. Backbone One Left Trigger Replacement, Remove the screw: passo 7, imagem 1 %32 Backbone One Left Trigger Replacement, Remove the screw: passo 7, imagem 2 %32
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Left Trigger Replacement, Remove the trigger: passo 8, imagem 1 %32 Backbone One Left Trigger Replacement, Remove the trigger: passo 8, imagem 2 %32
    • Remove the left trigger.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
Membro desde: 12/18/19
62.444 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.738 guias
1Comentário do guia
Where can I buy the trigger
Zach - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 61
Ao todo: 3,462
