Introdução
If you have a broken bookshelf that is ready for the trash then this guide is for you. Before starting your fast fix project please remember that you will need at least two people to complete your project. Through this process you will be taking a broken down bookshelf and turning it into a strong and sturdy shelf that will last a lifetime by simply replacing the back of the shelf. Please note that you will be using a jig saw during this process.
O que você precisa
Gather all pieces of the bookshelf if it fell apart or the shelf itself is still together.
Now that the base of the bookshelf is back together, we will need to measure out the size of board needed for the new backing.
Use the measuring tape and the square ruler to measure out the specific size you need. Use a pencil to draw the lines out so you can saw the piece out with precision.
Use the jig saw to cut the piece of plywood out following the lines you just drew.
4 outras pessoas executaram este guia.
