Ir para o conteúdo principal
Back Panel Removal
O que você precisa
  1. Back Panel Removal, Battery: passo 1, imagem 1 %32
    • Power down the computer and unplug the power adapter.
  2. Back Panel Removal: passo 2, imagem 1 %32
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Back Panel Removal: passo 3, imagem 1 %32 Back Panel Removal: passo 3, imagem 2 %32 Back Panel Removal: passo 3, imagem 3 %32
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Back Panel Removal, Back Panel Removal: passo 4, imagem 1 %32
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Back Panel Removal: passo 5, imagem 1 %32 Back Panel Removal: passo 5, imagem 2 %32
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
Conclusão
To replace the back panel, follow the steps in reverse.
Austin Bons
Membro desde: 09/22/16
1.131 Reputação
Autoria de 8 guias
Equipe
UC Davis, Team 2-2, Oliver Fall 2016 Membro de UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 49
Ao todo: 8,563
