Ir para o conteúdo principal
Back Panel Disassembly
O que você precisa
  1. Back Panel Disassembly, Back Panel Disassembly: passo 1, imagem 1 %32 Back Panel Disassembly, Back Panel Disassembly: passo 1, imagem 2 %32
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Back Panel Disassembly: passo 2, imagem 1 %32 Back Panel Disassembly: passo 2, imagem 2 %32
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Back Panel Disassembly: passo 3, imagem 1 %32 Back Panel Disassembly: passo 3, imagem 2 %32
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Back Panel Disassembly: passo 4, imagem 1 %32 Back Panel Disassembly: passo 4, imagem 2 %32
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Back Panel Disassembly: passo 5, imagem 1 %32 Back Panel Disassembly: passo 5, imagem 2 %32 Back Panel Disassembly: passo 5, imagem 3 %32
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Back Panel Disassembly: passo 6, imagem 1 %32 Back Panel Disassembly: passo 6, imagem 2 %32
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
Conclusão
Jordan Rosemeyer
Membro desde: 10/13/15
491 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 602
