Ir para o conteúdo principal
Back Cover Replacement
O que você precisa
  1. Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Back Cover Replacement: passo 2, imagem 1 %32 Back Cover Replacement: passo 2, imagem 2 %32
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Back Cover Replacement: passo 3, imagem 1 %32 Back Cover Replacement: passo 3, imagem 2 %32 Back Cover Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 16-1, Wollert Fall 2015 Membro de USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Duração total: 727
