Ir para o conteúdo principal
Baby Taylor Guitar String Replacement
O que você precisa
  1. Baby Taylor Guitar String Replacement, Guitar String Replacement: passo 1, imagem 1 %32 Baby Taylor Guitar String Replacement, Guitar String Replacement: passo 1, imagem 2 %32 Baby Taylor Guitar String Replacement, Guitar String Replacement: passo 1, imagem 3 %32
    • Rotate the tuner of the string you want to replace in a clockwise direction until it's loose.
    • You can either do it by hand (First Picture) or you can use the guitar string winder (Second picture).
  2. Baby Taylor Guitar String Replacement: passo 2, imagem 1 %32 Baby Taylor Guitar String Replacement: passo 2, imagem 2 %32
    • Grab a plier and pull out the bridge pin of the string you want to replace.
    • Make sure that you've completed step 1 first. The string has to be loose before doing this step.
  3. Baby Taylor Guitar String Replacement: passo 3, imagem 1 %32 Baby Taylor Guitar String Replacement: passo 3, imagem 2 %32 Baby Taylor Guitar String Replacement: passo 3, imagem 3 %32
    • Take out the string from the bridge and the tuning pin.
    • You can now throw away the string. You will not be needing it anymore.
  4. Baby Taylor Guitar String Replacement: passo 4, imagem 1 %32 Baby Taylor Guitar String Replacement: passo 4, imagem 2 %32
    • Grab the new string and place the end (ball-end) inside the bridge.
    • The ball-end of a string is the side of the string that has a ball shape. (Shown in picture 2)
  5. Baby Taylor Guitar String Replacement: passo 5, imagem 1 %32 Baby Taylor Guitar String Replacement: passo 5, imagem 2 %32
    • Place the bridge pin inside the bridge in order to lock in the new string.
    • Lightly hammer down the bridge pin to keep it from detaching.
  6. Baby Taylor Guitar String Replacement: passo 6, imagem 1 %32 Baby Taylor Guitar String Replacement: passo 6, imagem 2 %32
    • Cut the excess string with a plier.
    • Cut the string around 1.5 inches over the desired tuning pin. (Recommended by Taylor Guitars)
  7. Baby Taylor Guitar String Replacement: passo 7, imagem 1 %32
    • Place the new string inside the tuning pinhole.
    • It is recommended to place a really small portion of the string inside the pinhole to keep it from ripping your guitar bag. (As shown in the picture)
  8. Baby Taylor Guitar String Replacement: passo 8, imagem 1 %32 Baby Taylor Guitar String Replacement: passo 8, imagem 2 %32 Baby Taylor Guitar String Replacement: passo 8, imagem 3 %32
    • Rotate the tuners in a counter-clockwise direction to tighten the new string.
    • You can either tighten it by hand (First Picture) or you can use the guitar string winder (Second Picture).
  9. Baby Taylor Guitar String Replacement: passo 9, imagem 1 %32
    • Make sure your string is in tune and strum away!
Conclusão
Most guitar strings de-tune after they’ve been recently replaced. Tune your strings every once in a while for a few days and the strings will stay in tune.
Mohamed Saleh
Membro desde: 09/18/21
230 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 1,023
