Ir para o conteúdo principal
Baby Einstein Take Along Tunes Music Button Replacement
O que você precisa
  1. Baby Einstein Take Along Tunes Music Button  Replacement, Music Button: passo 1, imagem 1 %32
    • Place the device face down on a flat surface, so that the screws on the back are facing the ceiling.
  2. Baby Einstein Take Along Tunes Music Button  Replacement: passo 2, imagem 1 %32
    • Using a screwdriver loosen the four screws connecting the body of the device together.
  3. Baby Einstein Take Along Tunes Music Button  Replacement: passo 3, imagem 1 %32
    • Once unscrewed, pop the back of the device off using the plastic opening tool.
  4. Baby Einstein Take Along Tunes Music Button  Replacement: passo 4, imagem 1 %32
    • Place the front of the device face down.
  5. Baby Einstein Take Along Tunes Music Button  Replacement: passo 5, imagem 1 %32
    • Using the plastic opening tool, pop the music button off.
  6. Baby Einstein Take Along Tunes Music Button  Replacement: passo 6, imagem 1 %32
    • Gently pull the music button off and replace it with a new one. If you want to put a music button back in, the marked curve must line up with the one on the body.
Conclusão
Shreya Sunny
Membro desde: 09/04/15
607 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 2-2, Sullivan Fall 2015 Membro de USF Tampa, Team 2-2, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 758
