Ir para o conteúdo principal
Baby Einstein Take Along Tunes LED Replacement
O que você precisa
  1. Baby Einstein Take Along Tunes LED  Replacement, LED: passo 1, imagem 1 %32
    • Place the device face down on a flat surface, so that the screws on the back are facing the ceiling.
  2. Baby Einstein Take Along Tunes LED  Replacement: passo 2, imagem 1 %32
    • Using a screwdriver loosen the four screws connecting the body of the device together.
  3. Baby Einstein Take Along Tunes LED  Replacement: passo 3, imagem 1 %32
    • Once unscrewed, pop the back of the device off using the plastic opening tool.
  4. Baby Einstein Take Along Tunes LED  Replacement: passo 4, imagem 1 %32
    • Once unscrewed, take the back of the body and put it aside. We will be working with the front part of the device.
  5. Baby Einstein Take Along Tunes LED  Replacement: passo 5, imagem 1 %32
    • Using a screwdriver loosen the screws on the lights panel.
  6. Baby Einstein Take Along Tunes LED  Replacement: passo 6, imagem 1 %32
    • Using a plastic opening tool pop the light panel off. Be careful as to not rip any of the wires from the panel.
  7. Baby Einstein Take Along Tunes LED  Replacement: passo 7, imagem 1 %32 Baby Einstein Take Along Tunes LED  Replacement: passo 7, imagem 2 %32
    • Carefully pull the LED lights off with a pair of tweezers. Once off, put in and connect a replacement.
Conclusão
Uma outra pessoa concluiu este guia.
Shreya Sunny
Membro desde: 09/04/15
607 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 2-2, Sullivan Fall 2015 Membro de USF Tampa, Team 2-2, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 635
