Ir para o conteúdo principal
Baby Einstein Take Along Tunes Battery Socket Replacement
O que você precisa
  1. Baby Einstein Take Along Tunes Battery Socket Replacement, Battery Socket: passo 1, imagem 1 %32
    • Set the device on it's face with the back facing up.
  2. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 2, imagem 1 %32
    • Begin by removing all highlighted screws with a using a Phillips #1 Screwdriver.
  3. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 3, imagem 1 %32
    • Remove the battery plate with a plastic opening tool and set it aside.
  4. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 4, imagem 1 %32
    • Remove each battery with a plastic opening tool and set them aside.
  5. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 5, imagem 1 %32
    • Separate the device in two parts by using the plastic opening tool.
  6. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 6, imagem 1 %32
    • Remove the top piece and place it aside, keeping the bottom half with the mechanics.
  7. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 7, imagem 1 %32
    • Remove the highlighted screws using a Phillips #1 Screwdriver.
  8. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 8, imagem 1 %32
    • Use the plastic opening tool and carefully set the LED panel to the side, exposing the wires underneath.
  9. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 9, imagem 1 %32
    • With the precision tweezers, straighten the metal connectors to remove the terminals from the other side.
  10. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 10, imagem 1 %32 Baby Einstein Take Along Tunes Battery Socket Replacement: passo 10, imagem 2 %32
    • Sever the red wire from the metal connector with the precision tweezers.
  11. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 11, imagem 1 %32 Baby Einstein Take Along Tunes Battery Socket Replacement: passo 11, imagem 2 %32
    • Sever the black wire from the metal connector with the precision tweezers.
  12. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 12, imagem 1 %32 Baby Einstein Take Along Tunes Battery Socket Replacement: passo 12, imagem 2 %32
    • Flip the device on its face and remove the battery terminals with a metal spudger.
Conclusão
Shreya Sunny
Membro desde: 09/04/15
607 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 2-2, Sullivan Fall 2015 Membro de USF Tampa, Team 2-2, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 18
Duração total: 574
