Ir para o conteúdo principal
BRCK v1 Modem Ribbon Connector Replacement
O que você precisa
  1. BRCK v1 Modem Ribbon Connector Replacement, Top Cover: passo 1, imagem 1 %32
    • Place the face of the device showing BRCK face up.
  2. BRCK v1 Modem Ribbon Connector Replacement: passo 2, imagem 1 %32
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  3. BRCK v1 Modem Ribbon Connector Replacement: passo 3, imagem 1 %32
    • Remove the top cover.
  4. BRCK v1 Modem Ribbon Connector Replacement, Modem: passo 4, imagem 1 %32
    • Cut the black zip tie holding the modem down.
    • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
  5. BRCK v1 Modem Ribbon Connector Replacement: passo 5, imagem 1 %32
    • Remove the connection located on the edge of the modem.
  6. BRCK v1 Modem Ribbon Connector Replacement: passo 6, imagem 1 %32 BRCK v1 Modem Ribbon Connector Replacement: passo 6, imagem 2 %32
    • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
  7. BRCK v1 Modem Ribbon Connector Replacement: passo 7, imagem 1 %32 BRCK v1 Modem Ribbon Connector Replacement: passo 7, imagem 2 %32 BRCK v1 Modem Ribbon Connector Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
    • Lower the plate and gently pull the ribbon out of the face plate.
    • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
  8. BRCK v1 Modem Ribbon Connector Replacement: passo 8, imagem 1 %32 BRCK v1 Modem Ribbon Connector Replacement: passo 8, imagem 2 %32
    • Remove the modem from the device.
  9. BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: passo 9, imagem 1 %32 BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: passo 9, imagem 2 %32 BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: passo 9, imagem 3 %32
    • Using your fingers, apply equal force to each side of the black tab to loosen the connection.
    • Slide the ribbon out from under the black tab.
Conclusão
Jeret Buerger
Membro desde: 04/01/15
501 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-3, Lancaster Spring 2015 Membro de Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Ao todo: 264
