Ir para o conteúdo principal
BRCK v1 Battery Replacement
O que você precisa
  1. BRCK v1 Battery Replacement, Antenna: passo 1, imagem 1 %32
    • Stand the device on its side so the antenna is sitting on the top.
  2. BRCK v1 Battery Replacement: passo 2, imagem 1 %32 BRCK v1 Battery Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to grip the neck of the antenna(the part closest to the device).
    • Use opposite hand to twist off the body of the antenna.
  3. BRCK v1 Battery Replacement, Top Cover: passo 3, imagem 1 %32
    • Place the face of the device showing BRCK face up.
  4. BRCK v1 Battery Replacement: passo 4, imagem 1 %32
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  5. BRCK v1 Battery Replacement: passo 5, imagem 1 %32
    • Remove the top cover.
  6. BRCK v1 Battery Replacement, Motherboard: passo 6, imagem 1 %32 BRCK v1 Battery Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the nut and washer from the RF connector, located where the antenna was connected.
  7. BRCK v1 Battery Replacement: passo 7, imagem 1 %32 BRCK v1 Battery Replacement: passo 7, imagem 2 %32
    • Unplug the red, black, and yellow wire connection by lifting up.
  8. BRCK v1 Battery Replacement: passo 8, imagem 1 %32 BRCK v1 Battery Replacement: passo 8, imagem 2 %32 BRCK v1 Battery Replacement: passo 8, imagem 3 %32
    • Carefully insert tweezers under the black tab, and lift to release the clip.
    • Slide the ribbon out from under the clip to free the motherboard.
  9. BRCK v1 Battery Replacement: passo 9, imagem 1 %32
    • Remove outside rubber covers by lifting them out of place.
  10. BRCK v1 Battery Replacement: passo 10, imagem 1 %32 BRCK v1 Battery Replacement: passo 10, imagem 2 %32 BRCK v1 Battery Replacement: passo 10, imagem 3 %32
    • Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
    • Lift and pull out of place.
  11. BRCK v1 Battery Replacement, Battery: passo 11, imagem 1 %32 BRCK v1 Battery Replacement, Battery: passo 11, imagem 2 %32 BRCK v1 Battery Replacement, Battery: passo 11, imagem 3 %32
    • Flip device upside down. Hold the device and tap into your other hand with varying force to remove battery.
    • This may take a few tries to remove the battery.
Conclusão
Jeret Buerger
Membro desde: 04/01/15
501 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-3, Lancaster Spring 2015 Membro de Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 238
