Introdução
Diese Anleitung zeigt, wie du den BRAUN cruZer6 Haar- und Barttrimmer Type 5417 zerlegen und den Akku tauschen kannst.
Entferne den Scherkopf.
Entferne die beiden Schlitzschrauben, mit denen die Abdeckung am Handstück befestigt ist.
Nimm die Abdeckung ab.
Jetzt ist eine gute Gelegenheit, um das Innere des Gerätes zu reinigen. Haare können den Kontakt des Akkus stören.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
16 outras pessoas concluíram este guia.
8 comentários
Your guide saved me from purchasing a new device.
After replacing the batteries it works again like a charm!
Thanks this was helpful. The Braun Series 3 Hair Clipper HC3050 has a VERY similar design. Some additional notes: After removing the screws, it takes a bit of force to get the back separated from the front. I had to gently pry it apart with a screw driver. The very inside is slightly different, but same concept.
Die Anleitung war sehr hilfreich.
Der Austausch der Batterien ging ziemlich gut.
What's the battery type? Triple A? I can read ni-mh 1.2v 1230 (mah?) thanks
NiMH 1.2V 800mAh
The batteries contacts are soldered to the board. How do i get them off without breaking the contact parts? and how do i get them to stick onto the new batteries? (I don’t have a soldering iron)
Thanks in advance !!
You have to solder anyway. The batteries you have to buy, are pre-installed with a solder tail. You will find them on amazon (AAA, 1,2V + solder tail .. they are Eneloops for example in such version) So: no soldering, no solution.
I think one pcc— 1.2 V 1800 mah AA battary
I think I already posted a comment but I can’t see it.
Your excellent guide saved me from purchasing a new beard trimmer. After replacing the batteries it works again like a charm!
Thank you
King Arthur - Responder
