Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
A guide to removing and re-installing the main brush motor inside bObsweep. For detailed video instructions visit https://www.youtube.com/watch?v=CnS85w_l...
O que você precisa
Flip Bob over and remove the 7 screws around which hold the cover together.
Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
1. On the bottom left corner: a small connector with red, black and white wires.
2. One thick white wire that attaches on the right side of the previous connector.
3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
Place the cover aside and begin your repair.
The main brush motor sits in front of bOb’s left wheel, attached to the motherboard by two pairs of twisted wires, one pair is red and white, the other pink and black.
Press on the white tab and pull up to release the circuit plug.
Lift the brush motor up to remove.
To reassemble your device, follow the Closing bObsweep Guide.
