Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the four 15.5 mm PH2 screws securing the base plate to the device.
Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
Remove all four 15.5 mm PH2 screws holding the power supply down.
Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
Pick up the power supply and remove the fourth cable from the underside of the power supply.
Remove the power supply.
Remove the five 15.5 mm PH2 screws holding the motherboard down.
Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
Remove the motherboard.
Remove the eight 15.5 mm PH2 screws holding the plastic insert down.
Remove the plastic insert.
Remove the three 15.5 mm PH2 screws holding the metal insert down.
Remove the metal insert.
Remove the three 19 mm PH2 screws holding the metal subwoofer cover down.
Remove the subwoofer cover.
Remove the four 19 mm PH2 screws holding the subwoofer in place.
Remove the subwoofer by pulling towards the back of the device while tucking the wire under the plastic enclosure.
Uma outra pessoa concluiu este guia.
