Introdução
This guide will show the steps needed to remove the power supply from the BOSE SoundTouch 30.
Peças
Não são necessárias peças.
  1. Remove the four 15.5 mm PH2 screws securing the base plate to the device. Remove the four 15.5 mm PH2 screws securing the base plate to the device.
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. Remove the six 15.5mm PH2  screws securing the grille and rear panel to the device.
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards. There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
  5. Remove all four 15.5 mm PH2 screws holding the power supply down.
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
  6. Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling. Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
Conclusão
3 outras pessoas concluíram este guia.
Brennen Irey
771 reputação
6 Guides authored
Equipe
Cal Poly, Team S16-G2, Livingston Spring 2018 Membro de Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Membros
6 Guides authored
where can we buy the [power supply unit, as i have messed mine by using 220v instead of 110v
Hitesh Gohill - Responder
Hello. Do you want to exchange power supplies?
Contact me please!
Tomás Rosales -
I have the opposite problem. Bought the 110v instead of the 220v and now I have to use a step down transformer. Wanna exchange power supplies?
tomas@familiarosales.cl
Tomás Rosales - Responder
how do I buy a new power unit?
William Painap - Responder
Hi William
Im Kevin from Sydney, Australia.
I’d like to buy a power supply module for SoundTouch 30 as well but I cannot find anywhere.
Please let me know if you got any good news.
Cheers!
Kev
Kevin Hoang -
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 108
Todo: 902
