Ir para o conteúdo principal
BMW 325i e90 Inner Tail Light Bulb Replacement
O que você precisa
  1. BMW 325i e90 Inner Tail Light Bulb Replacement, Inner Tail Light Bulb: passo 1, imagem 1 %32 BMW 325i e90 Inner Tail Light Bulb Replacement, Inner Tail Light Bulb: passo 1, imagem 2 %32
    • Start by opening the trunk and locating the 8 plastic studs holding the trunk trim panel in place.
    • To remove the studs, dig a trim removal tool under them and use leverage to pop them out.
  2. BMW 325i e90 Inner Tail Light Bulb Replacement: passo 2, imagem 1 %32 BMW 325i e90 Inner Tail Light Bulb Replacement: passo 2, imagem 2 %32
    • Once the trim panel comes loose, it'll still be fastened to the trunck by a wire.
    • Make sure to leave the trim panel hanging since it'll expose the taillight housing enough to work on it in the next step.
  3. BMW 325i e90 Inner Tail Light Bulb Replacement: passo 3, imagem 1 %32 BMW 325i e90 Inner Tail Light Bulb Replacement: passo 3, imagem 2 %32
    • With the tail light bulb socket exposed, you'll need to first disconnect the wiring and then squeeze the plastic clip to release the entire bulb socket.
  4. BMW 325i e90 Inner Tail Light Bulb Replacement: passo 4, imagem 1 %32 BMW 325i e90 Inner Tail Light Bulb Replacement: passo 4, imagem 2 %32
    • Once you remove the bulb socket simply remove the faulty bulb by twisting and pulling, then replace it with a new one. Place the socket back in and listen for it to click.
Conclusão
Once the new bulb is installed and the bulb housing is back in place, reconnect the wiring. Now simply line up the trunk trim panel and insert the studs in their corresponding holes to finish your bulb replacement.
Christopher Garcia
Membro desde: 03/20/24
109 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 65
Duração total: 143
