Introdução
This is a simple guide to replacing a faulty or broken inner tail light bulb and contains few, easy-to-follow steps.
For this guide, you'll need a replacement tail light bulb and a trim panel tool.
O que você precisa
Start by opening the trunk and locating the 8 plastic studs holding the trunk trim panel in place.
To remove the studs, dig a trim removal tool under them and use leverage to pop them out.
Once the new bulb is installed and the bulb housing is back in place, reconnect the wiring. Now simply line up the trunk trim panel and insert the studs in their corresponding holes to finish your bulb replacement.
