Ir para o conteúdo principal
BLU WIN HD LTE Camera Replacement
O que você precisa
  1. BLU WIN HD LTE Camera Replacement, Back Case: passo 1, imagem 1 %32
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Camera Replacement: passo 2, imagem 1 %32
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Camera Replacement, Frame Cover: passo 3, imagem 1 %32
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Camera Replacement: passo 4, imagem 1 %32
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Camera Replacement, Camera: passo 5, imagem 1 %32 BLU WIN HD LTE Camera Replacement, Camera: passo 5, imagem 2 %32 BLU WIN HD LTE Camera Replacement, Camera: passo 5, imagem 3 %32
    • Pry off the low profile connector located on the right side of the camera device.
  6. BLU WIN HD LTE Camera Replacement: passo 6, imagem 1 %32
    • Pull the camera out.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 311
