Ir para o conteúdo principal
BLU WIN HD LTE Battery Replacement
O que você precisa
  1. BLU WIN HD LTE Battery Replacement, Back Case: passo 1, imagem 1 %32
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Battery Replacement: passo 2, imagem 1 %32
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Battery Replacement, Frame Cover: passo 3, imagem 1 %32
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Battery Replacement: passo 4, imagem 1 %32
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Battery Replacement, Battery: passo 5, imagem 1 %32 BLU WIN HD LTE Battery Replacement, Battery: passo 5, imagem 2 %32
    • Remove the battery out using the black nylon spudger.
    • Battery is secured by glue so use more force to take it out.
Conclusão
2 comentários
I replaced the battery but now there is a symbol on the screen, box with a question mark, what does that mean?
raybrooks - Responder
I hope someone else has had this issue an has a solution. Thank you in advance for any and all help.
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 697
