Introdução
This replacement guide will show you how to replace a dead, or broken battery for the BLU Tank II cell phone. Tools, or prerequisite knowledge, will not be required for the replacement of the battery.
With the screen facing you, find the left corner of the phone. There should be a visible groove.
With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
Lift the battery up and carefully remove the battery.
Uma outra pessoa concluiu este guia.
