Ir para o conteúdo principal
BLU Studio G Battery Replacement
O que você precisa
  1. BLU Studio G Battery Replacement, Battery: passo 1, imagem 1 %32 BLU Studio G Battery Replacement, Battery: passo 1, imagem 2 %32 BLU Studio G Battery Replacement, Battery: passo 1, imagem 3 %32
    • To remove the back cover, locate the safety indented notch on the bottom left corner as the screen is facing down.
    • Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
    • Set back cover aside.
  2. BLU Studio G Battery Replacement: passo 2, imagem 1 %32 BLU Studio G Battery Replacement: passo 2, imagem 2 %32
    • Locate the notch at the bottom of the battery for safe removal.
    • Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
    • Set battery aside and insert new one .
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 20
Ao todo: 573
