Introdução
This guide provides steps on how to replace the battery of the Blu Studio 7.0 II.
O que você precisa
Locate the seam between the black and silver pieces of the phone.
Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
Using the PH00 screw driver, remove the two 3mm screws.
Remove the metal clip that connects the battery ribbon to the motherboard by lifting up. Precision tweezers work best for this part.
Using the black spudger, carefully but firmly pry the battery out of the housing.
Uma outra pessoa concluiu este guia.
