Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The battery for the BLU Studio 5.5 is the first component that should be removed before working on replacement for any other components. A common troubleshooting procedure to reset a mobile device follows these same steps; removing the back panel, the battery, reassembling, and powering the device back on.
O que você precisa
Locate the notch to remove the back panel at the lower left corner of the panel.
Insert the plastic opening tool or a fingernail into the notch.
Apply force upwards until back panel becomes loosened.
