Ir para o conteúdo principal
BLU Studio 5.0 S II Speaker Replacement
O que você precisa
  1. BLU Studio 5.0 S II Speaker Replacement, Remove back cover.: passo 1, imagem 1 %32
    • Remove the back cover on the phone with the plastic opening tool.
  2. BLU Studio 5.0 S II Speaker Replacement, Remove battery: passo 2, imagem 1 %32
    • Remove battery with plastic opening tool.
  3. BLU Studio 5.0 S II Speaker Replacement, Remove screws: passo 3, imagem 1 %32
    • On the bottom part of the back of the phone with a Phillips screwdriver #00 tool remove the 6 screws that hold the speaker in place.
  4. BLU Studio 5.0 S II Speaker Replacement, Remove speaker plastic backing: passo 4, imagem 1 %32
    • After removing screws gently pull off the speaker from the back of the phone.
  5. BLU Studio 5.0 S II Speaker Replacement, Remove speaker.: passo 5, imagem 1 %32
    • Remove the speaker from the backing of the speaker holder.
  6. BLU Studio 5.0 S II Speaker Replacement, Replace speaker.: passo 6, imagem 1 %32
    • Replace the old speaker with a new speaker. Put it back in where the old speaker was.
  7. BLU Studio 5.0 S II Speaker Replacement, Put the screws back on: passo 7, imagem 1 %32
    • Insert the plastic backing of the speaker back in the phone.
    • Put the six screws back in the backing of the phone to hold the plastic backing securely.
Conclusão
Maria Juzaino
Membro desde: 10/25/14
499 Reputação
Autoria de 3 guias
Equipe
Gateway, Team 1-3, Johnson Fall 2014 Membro de Gateway, Team 1-3, Johnson Fall 2014
GCC-JOHNSON-F14S1G3
Membros da 3
Autoria de 5 guias
2 comentários
Excellent instruction! Great pictures as well! Well done+!
Kelly - Responder
Can you upload a guide on how to replace this device's screen? Pretty much appreciated.
Moe Ojeda - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 1,627
