Ir para o conteúdo principal
BLU Studio 5.0 S II Camera Replacement
O que você precisa
  1. BLU Studio 5.0 S II Camera Replacement, Remove back cover: passo 1, imagem 1 %32
    • Remove the back cover of phone with the plastic opening tool.
  2. BLU Studio 5.0 S II Camera Replacement, Remove battery: passo 2, imagem 1 %32
    • Remove the battery with the plastic opening tool.
  3. BLU Studio 5.0 S II Camera Replacement, Remove screws: passo 3, imagem 1 %32
    • Use the Philips #00 screwdriver to remove the nine screws that the top back part of the phone has.
  4. BLU Studio 5.0 S II Camera Replacement, Remove the plastic backing of phone: passo 4, imagem 1 %32
    • Once you take off the screws off the phone remove the plastic backing .
  5. BLU Studio 5.0 S II Camera Replacement: passo 5, imagem 1 %32 BLU Studio 5.0 S II Camera Replacement: passo 5, imagem 2 %32
    • Remove the ribbon cable carefully on all four sides of the motherboard of the phone.
  6. BLU Studio 5.0 S II Camera Replacement, Remove screws from motherboard: passo 6, imagem 1 %32
    • Take off the four interior screws that are on the motherboard of the phone.
  7. BLU Studio 5.0 S II Camera Replacement, Remove plastic film: passo 7, imagem 1 %32
    • Remove the ribbon cable next to the camera carefully.
  8. BLU Studio 5.0 S II Camera Replacement, Remove motherboard: passo 8, imagem 1 %32
    • Remove the motherboard of the phone and replace camera.
Conclusão
Maria Juzaino
Membro desde: 10/25/14
499 Reputação
Autoria de 3 guias
Equipe
Gateway, Team 1-3, Johnson Fall 2014 Membro de Gateway, Team 1-3, Johnson Fall 2014
GCC-JOHNSON-F14S1G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 1,990
