Ir para o conteúdo principal
BLU Studio 5.0 II Volume Button Replacement
O que você precisa
  1. BLU Studio 5.0 II Volume Button Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II Volume Button Replacement: passo 2, imagem 1 %32 BLU Studio 5.0 II Volume Button Replacement: passo 2, imagem 2 %32
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II Volume Button Replacement: passo 3, imagem 1 %32 BLU Studio 5.0 II Volume Button Replacement: passo 3, imagem 2 %32 BLU Studio 5.0 II Volume Button Replacement: passo 3, imagem 3 %32
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II Volume Button Replacement, Back Case: passo 4, imagem 1 %32
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  5. BLU Studio 5.0 II Volume Button Replacement: passo 5, imagem 1 %32 BLU Studio 5.0 II Volume Button Replacement: passo 5, imagem 2 %32 BLU Studio 5.0 II Volume Button Replacement: passo 5, imagem 3 %32
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
  6. BLU Studio 5.0 II Volume Button Replacement, Volume Button: passo 6, imagem 1 %32 BLU Studio 5.0 II Volume Button Replacement, Volume Button: passo 6, imagem 2 %32
    • Locate the volume button on the right side of the phone after removing back case.
    • Using a spudger carefully wedge between button and phone and carefully pry away from the phone.
    • Once removed the yellow buttons will be visible.
Conclusão
Zack Miliziano
Membro desde: 02/09/16
146 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 7-5, Cheng Spring 2016 Membro de USF Tampa, Team 7-5, Cheng Spring 2016
USFT-CHENG-S16S7G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 231
