Ir para o conteúdo principal
BLU Studio 5.0 II SIM Card Replacement
  1. BLU Studio 5.0 II SIM Card Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II SIM Card Replacement: passo 2, imagem 1 %32 BLU Studio 5.0 II SIM Card Replacement: passo 2, imagem 2 %32
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II SIM Card Replacement: passo 3, imagem 1 %32 BLU Studio 5.0 II SIM Card Replacement: passo 3, imagem 2 %32 BLU Studio 5.0 II SIM Card Replacement: passo 3, imagem 3 %32
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II SIM Card Replacement, SIM Card: passo 4, imagem 1 %32
    • Locate the SIM Card above the battery.
  5. BLU Studio 5.0 II SIM Card Replacement: passo 5, imagem 1 %32 BLU Studio 5.0 II SIM Card Replacement: passo 5, imagem 2 %32
    • Use your finger to apply a small pressure on the SIM Card.
    • Slide your finger downwards in order to remove the SIM Card from the slot.
Conclusão
Ricardo Sarabia
Membro desde: 02/09/16
1.069 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 7-5, Cheng Spring 2016 Membro de USF Tampa, Team 7-5, Cheng Spring 2016
USFT-CHENG-S16S7G5
Membros da 3
Autoria de 7 guias
3 comentários
it seems i have  problem geting the phone working through trac phone they its working but cant call out it blu xtreme 2.5 whats up?
anthony - Responder
my phone wont call out tracphone say its working but no its a BLU xtreme 2.5 any answers?
anthony - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 1,061
