Introdução
Use this guide in order to successfully remove and replace the rear-facing camera on your BLU Studio 5.0 II phone.
O que você precisa
Locate the four 3mm screws on each side of the back panel.
Use a Phillips #00 screwdriver to remove the eight screws.
Locate the camera, which is centered on the upper part of the motherboard.
Use tweezers to lift the camera slowly.
Carefully pull the camera out of the motherboard.
Quase terminado!
Conclusão
