Introdução
Follow this guide to replace your scratched or damaged BLU R2 Plus back cover. This may also help you gain access to the sim card and other components of this phone.
O que você precisa
Be sure that your BLU R2 Plus is completely powered off and has less than 25% battery left. This will lower the chance of your battery catching fire and your logic board/motherboard shorting out.
Insert your pick in the top left-hand corner where the little indent is.
Slide the pick all the way around the phone until the back cover is loose and ready to be released.
Remove the Back Cover to gain access to sim card trays, the memory card slot, or just to replace it.
Uma outra pessoa concluiu este guia.
