Introdução
A faulty motherboard can render your smartphone inoperable. This guide demonstrates the steps required to replace the motherboard on a BLU Life XL smartphone.
O que você precisa
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
Remove the rear cover using your hands at the lip on the device back cover. No tools required.
Remove the battery by lifting the lower edge of the battery up first.
Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
Run the prying tool around the entire phone separating the rear plate from the frame.
Remove the two 12x3mm screws using the Phillips #000 screwdriver.
Remove the ribbon cables.
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the white ZIF connector then remove the cable connecting the digitizer to the motherboard by gently pulling.
An adhesive pad attaches this component to the motherboard. To remove it, use a pair of tweezers to gently pry it upwards.
Uma outra pessoa concluiu este guia.
Um comentário
how i identified the components in this motherboard
