Ir para o conteúdo principal
BLU Life X8 Daughterboard Replacement
O que você precisa
  1. BLU Life X8 Daughterboard  Replacement, Battery: passo 1, imagem 1 %32 BLU Life X8 Daughterboard  Replacement, Battery: passo 1, imagem 2 %32
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Daughterboard  Replacement: passo 2, imagem 1 %32
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Daughterboard  Replacement: passo 3, imagem 1 %32
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Daughterboard  Replacement, Motherboard: passo 4, imagem 1 %32 BLU Life X8 Daughterboard  Replacement, Motherboard: passo 4, imagem 2 %32
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
  5. BLU Life X8 Daughterboard  Replacement: passo 5, imagem 1 %32
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
  6. BLU Life X8 Daughterboard  Replacement: passo 6, imagem 1 %32
    • Once all the clips have been released, lift the frame and set it aside.
  7. BLU Life X8 Daughterboard  Replacement: passo 7, imagem 1 %32 BLU Life X8 Daughterboard  Replacement: passo 7, imagem 2 %32
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
  8. BLU Life X8 Daughterboard  Replacement: passo 8, imagem 1 %32 BLU Life X8 Daughterboard  Replacement: passo 8, imagem 2 %32 BLU Life X8 Daughterboard  Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
  9. BLU Life X8 Daughterboard  Replacement: passo 9, imagem 1 %32
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
  10. BLU Life X8 Daughterboard  Replacement: passo 10, imagem 1 %32
    • Slowly lift the vibration motor away from the frame and peel up the tape.
  11. BLU Life X8 Daughterboard  Replacement, Daughterboard: passo 11, imagem 1 %32
    • Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
  12. BLU Life X8 Daughterboard  Replacement: passo 12, imagem 1 %32
    Comprar
    • Remove the transparent tape covering one of the ribbon connectors using the tweezers.
  13. BLU Life X8 Daughterboard  Replacement: passo 13, imagem 1 %32 BLU Life X8 Daughterboard  Replacement: passo 13, imagem 2 %32 BLU Life X8 Daughterboard  Replacement: passo 13, imagem 3 %32
    • Use the tweezers to lift the black and beige tabs securing the ribbon cables.
    • Pull back on the ribbon cables to release them from their connectors.
  14. BLU Life X8 Daughterboard  Replacement: passo 14, imagem 1 %32
    • Lift the daughterboard from the frame using the plastic opening tool.
Conclusão
Nicholas Harmon
Membro desde: 10/05/17
158 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S1-G2, Nance Fall 2017 Membro de USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 237
