Introdução
The daughterboard is connected to the bottom speaker, the USB port, and the touch screen, so if one of these isn't functioning properly the daughterboard may need to be replaced. This guide explains how to access, remove, and replace the daughterboard of your BLU Life X8.
O que você precisa
Flip the phone over so that the screen is facing down.
Slide the opening tool between the micro-USB port and the back cover.
Use the opening tool to create a gap.
Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
