Ir para o conteúdo principal
BLU Life X8 Back Camera Replacement
O que você precisa
  1. BLU Life X8 Back Camera Replacement, Battery: passo 1, imagem 1 %32 BLU Life X8 Back Camera Replacement, Battery: passo 1, imagem 2 %32
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Back Camera Replacement: passo 2, imagem 1 %32
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Back Camera Replacement: passo 3, imagem 1 %32
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Back Camera Replacement, Back Camera: passo 4, imagem 1 %32 BLU Life X8 Back Camera Replacement, Back Camera: passo 4, imagem 2 %32
    • Use the Phillips #00 (1.5mm) bit to undo the (9) screws from the back of the device.
  5. BLU Life X8 Back Camera Replacement: passo 5, imagem 1 %32
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from reengaging.
  6. BLU Life X8 Back Camera Replacement: passo 6, imagem 1 %32
    • Once all the clips have been released, pull back the frame and set it aside.
  7. BLU Life X8 Back Camera Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to unlock the ribbon cable from the motherboard
    • The ribbon cable should be free. Pull back on the ribbons to release it from the connector
  8. BLU Life X8 Back Camera Replacement: passo 8, imagem 1 %32
    • Lift the back camera from its housing
    • The back camera may be glued to the phone
Conclusão
Uma outra pessoa concluiu este guia.
Alexander Prasil
Membro desde: 09/28/17
546 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G2, Nance Fall 2017 Membro de USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Ao todo: 329
