Ir para o conteúdo principal
BLU Energy X Plus MotherBoard Replacement
O que você precisa
  1. BLU Energy X Plus MotherBoard Replacement, Battery: passo 1, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement, Battery: passo 1, imagem 2 %32
    • Before disassembling your BLU Energy X Plus, make sure it is powered off.
    • Flip your device to the left side facing up and take out the SD card tray using the SIM card eject tool. You will insert the tool in at an angle and lift the tray up.
  2. BLU Energy X Plus MotherBoard Replacement: passo 2, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 2, imagem 2 %32
    • Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out.
  3. BLU Energy X Plus MotherBoard Replacement: passo 3, imagem 1 %32
    • Flip your device over so your back cover is facing up.
  4. BLU Energy X Plus MotherBoard Replacement: passo 4, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 4, imagem 2 %32
    • Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off.
  5. BLU Energy X Plus MotherBoard Replacement: passo 5, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 5, imagem 2 %32
    • Remove the six silver screws from the cover plate, and one black screw from the top.
    • Use the screwdriver head J000 to remove all the screws.
    • Six silver screws, all 1.5mm in length.
    • One black screw, 1mm in length.
  6. BLU Energy X Plus MotherBoard Replacement: passo 6, imagem 1 %32
    • After all the screws are out, lift the protective metal cover off of the phone. Lift from the bottom of the cover.
  7. BLU Energy X Plus MotherBoard Replacement: passo 7, imagem 1 %32
    • Use the small blue plastic opening tool to lift the contact attached to the battery from the motherboard of the phone.
  8. BLU Energy X Plus MotherBoard Replacement: passo 8, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 8, imagem 2 %32
    • Use the small blue plastic opening tool to lift the battery from the bottom with little force because the battery will be glued in.
    • Then, use your hand to remove the battery completely.
  9. BLU Energy X Plus MotherBoard Replacement, Camera: passo 9, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement, Camera: passo 9, imagem 2 %32
    • Disconnect the contact patch using the small blue plastic opening tool.
  10. BLU Energy X Plus MotherBoard Replacement: passo 10, imagem 1 %32
    • Loosen the camera from the glue using the small blue plastic opening tool.
  11. BLU Energy X Plus MotherBoard Replacement: passo 11, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 11, imagem 2 %32
    • After loosening the glue from the bottom of the camera, lift the camera out of the phone.
  12. BLU Energy X Plus MotherBoard Replacement, MotherBoard: passo 12, imagem 1 %32
    • Remove the black screw using a screwdriver head J000.
  13. BLU Energy X Plus MotherBoard Replacement: passo 13, imagem 1 %32
    • Lift the black tab on the zero insert force connector on the lower left side of the motherboard using a small blue plastic opening tool.
  14. BLU Energy X Plus MotherBoard Replacement: passo 14, imagem 1 %32
    • Lift the black tab on the zero insert force connector on the lower right side of the motherboard using a small blue plastic opening tool.
  15. BLU Energy X Plus MotherBoard Replacement: passo 15, imagem 1 %32
    • Remove the yellow tape that's on the black panel using your fingers.
  16. BLU Energy X Plus MotherBoard Replacement: passo 16, imagem 1 %32
    • Lift the black tab on the zero insert force connector on the top left side of the motherboard using a small blue plastic opening tool.
  17. BLU Energy X Plus MotherBoard Replacement: passo 17, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 17, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a fine nose pair of tweezers to pull the ribbon cable from the zero insert force connector with little force to remove the contact connecter from the motherboard.
  18. BLU Energy X Plus MotherBoard Replacement: passo 18, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 18, imagem 2 %32
  19. BLU Energy X Plus MotherBoard Replacement: passo 19, imagem 1 %32
  20. BLU Energy X Plus MotherBoard Replacement: passo 20, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 20, imagem 2 %32
    • Lift the small processor using a pair of tweezers.
    • Then, lift up the motherboard using your hand, lifting from the top of the motherboard.
  21. BLU Energy X Plus MotherBoard Replacement: passo 21, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 21, imagem 2 %32
    • Remove the zero insert force connector that's on the back side of the motherboard using a small blue plastic opening tool to lift up the black tab. Then pull the motherboard out of the phone.
    • Pull the motherboard vertically to pull the motherboard from the phone. It should still be attached by a wire on the left side.
  22. BLU Energy X Plus MotherBoard Replacement: passo 22, imagem 1 %32 BLU Energy X Plus MotherBoard Replacement: passo 22, imagem 2 %32 BLU Energy X Plus MotherBoard Replacement: passo 22, imagem 3 %32
    • Remove the connector wire from the motherboard using your finger nails. You will need to pull from the gold colored connecter, which is attached to the motherboard.
    • And, there's your motherboard.
Conclusão
woodjake94
Membro desde: 02/09/16
638 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 2-121, Cagle Spring 2016 Membro de USF Tampa, Team 2-121, Cagle Spring 2016
USFT-CAGLE-S16S2G121
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 909
