Ir para o conteúdo principal
BLU Dash Music 4.0 Speaker Replacement
O que você precisa
  1. BLU Dash Music 4.0 Speaker Replacement, Remove the Back Cover: passo 1, imagem 1 %32
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Speaker Replacement, Remove the Battery: passo 2, imagem 1 %32
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: passo 3, imagem 1 %32 BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: passo 3, imagem 2 %32
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: passo 4, imagem 1 %32 BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: passo 4, imagem 2 %32
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the covers apart.
  5. BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: passo 5, imagem 1 %32 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: passo 5, imagem 2 %32 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: passo 5, imagem 3 %32
    • Locate the speaker
    • Wedge the plastic opening tool between the speaker and the circuit board. Gently pry the speaker off the circuit board.
    • Use a soldering iron to remove the two wires that connect the speaker to the circuit board.
  6. BLU Dash Music 4.0 Speaker Replacement, Place the New Speaker: passo 6, imagem 1 %32
    • Use the soldering iron to connect the two wires, that are attached to the speaker, to the circuit board.
    • Place the new speaker onto the circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 471
