Ir para o conteúdo principal
BLU Dash Music 4.0 SIM Card Replacement
O que você precisa
  1. BLU Dash Music 4.0 SIM Card Replacement, Remove Back Cover: passo 1, imagem 1 %32
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 SIM Card Replacement, Remove the Battery: passo 2, imagem 1 %32
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 SIM Card Replacement, Remove the SIM Cards: passo 3, imagem 1 %32
    • Remove the SIM card(s) by pulling them out of their slot(s).
  4. BLU Dash Music 4.0 SIM Card Replacement, Insert the New SIM Card(s): passo 4, imagem 1 %32
    • Insert the new SIM card(s) into the slot(s) by pushing them into place with the proper orientation.
Conclusão
Equipe
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,491
