Ir para o conteúdo principal
BLU Dash JR D140 Digitizer Replacement
O que você precisa
  1. BLU Dash JR D140 Digitizer Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. BLU Dash JR D140 Digitizer Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool or finger, pull out the battery.
  3. BLU Dash JR D140 Digitizer Replacement, Digitizer: passo 3, imagem 1 %32
    • Remove the four 4.0mm Phillips #1 screws.
  4. BLU Dash JR D140 Digitizer Replacement: passo 4, imagem 1 %32
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. BLU Dash JR D140 Digitizer Replacement: passo 5, imagem 1 %32
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. BLU Dash JR D140 Digitizer Replacement: passo 6, imagem 1 %32
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. BLU Dash JR D140 Digitizer Replacement: passo 7, imagem 1 %32
    • Pull the ribbon cable out of the ZIF connector.
  8. BLU Dash JR D140 Digitizer Replacement: passo 8, imagem 1 %32
    • When the ribbon cable is removed from the ZIF connector, peel off the power, sticky button using a plastic opening tool.
  9. BLU Dash JR D140 Digitizer Replacement: passo 9, imagem 1 %32
    • Peel off the volume sticky button.
  10. BLU Dash JR D140 Digitizer Replacement: passo 10, imagem 1 %32 BLU Dash JR D140 Digitizer Replacement: passo 10, imagem 2 %32
    • Separate the screen cover from the motherboard using the plastic opening tool. And don't forget that your phone can mess up if u separate the motherboard from the screen cover
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
Conclusão
5 outras pessoas executaram este guia.
Nathanael
Membro desde: 07/23/15
233 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 33
Ao todo: 1,397
