Ir para o conteúdo principal
BLU Dash 3.5 Volume and Lock Button Replacement
O que você precisa
  1. BLU Dash 3.5 Volume and Lock Button Replacement, Battery: passo 1, imagem 1 %32 BLU Dash 3.5 Volume and Lock Button Replacement, Battery: passo 1, imagem 2 %32 BLU Dash 3.5 Volume and Lock Button Replacement, Battery: passo 1, imagem 3 %32
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Volume and Lock Button Replacement: passo 2, imagem 1 %32 BLU Dash 3.5 Volume and Lock Button Replacement: passo 2, imagem 2 %32
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Volume and Lock Button Replacement, Volume and Lock Button: passo 3, imagem 1 %32 BLU Dash 3.5 Volume and Lock Button Replacement, Volume and Lock Button: passo 3, imagem 2 %32
    • Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Volume and Lock Button Replacement: passo 4, imagem 1 %32 BLU Dash 3.5 Volume and Lock Button Replacement: passo 4, imagem 2 %32
    • Remove volume and lock buttons by lifting them gently from the casing.
Conclusão
Paige Shirley
Membro desde: 03/01/17
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G2, Harley Spring 2017 Membro de IUPUI, Team S1-G2, Harley Spring 2017
IUPUI-HARLEY-S17S1G2
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 180
