Ir para o conteúdo principal
BLU Dash 3.5 Camera Replacement
O que você precisa
  1. BLU Dash 3.5 Camera Replacement, Battery: passo 1, imagem 1 %32 BLU Dash 3.5 Camera Replacement, Battery: passo 1, imagem 2 %32 BLU Dash 3.5 Camera Replacement, Battery: passo 1, imagem 3 %32
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Camera Replacement: passo 2, imagem 1 %32 BLU Dash 3.5 Camera Replacement: passo 2, imagem 2 %32
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Camera Replacement, Camera: passo 3, imagem 1 %32 BLU Dash 3.5 Camera Replacement, Camera: passo 3, imagem 2 %32 BLU Dash 3.5 Camera Replacement, Camera: passo 3, imagem 3 %32
    • Use the J000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Camera Replacement: passo 4, imagem 1 %32 BLU Dash 3.5 Camera Replacement: passo 4, imagem 2 %32
    • Locate camera module on inside of the black plastic back panel
    • Note the orientation of the camera.
    • Use tweezers to carefully remove the camera.
Conclusão
victoria dorony
Membro desde: 09/28/15
22 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-2, Garvin Fall 2015 Membro de Ohio State, Team 1-2, Garvin Fall 2015
OSU-GARVIN-F15S1G2
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 333
