Ir para o conteúdo principal
BLACK and DECKER BDERO100 Hook and Loop System Replacement
O que você precisa
  1. BLACK and DECKER BDERO100 Hook and Loop System Replacement, Hook and Loop System: passo 1, imagem 1 %32
    • Remove the sanding paper from the velcro.
  2. BLACK and DECKER BDERO100 Hook and Loop System Replacement: passo 2, imagem 1 %32
    • Select the JIS - J1 bit or the most appropriate bit to match the screws for your model.
  3. BLACK and DECKER BDERO100 Hook and Loop System Replacement: passo 3, imagem 1 %32 BLACK and DECKER BDERO100 Hook and Loop System Replacement: passo 3, imagem 2 %32
    • Use the Bit Driver to take off the four 12.5 mm Phillips screws at the base of the hook-and-loop system.
    • Be careful not to lose the lock washers (black rings).
  4. BLACK and DECKER BDERO100 Hook and Loop System Replacement: passo 4, imagem 1 %32 BLACK and DECKER BDERO100 Hook and Loop System Replacement: passo 4, imagem 2 %32
    • Once all screws and washers have been removed, hold the hook and loop system and separate it from the device.
Conclusão
Christian Moss
Membro desde: 02/10/16
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-5, Sullivan Spring 2016 Membro de USF Tampa, Team 1-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G5
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 1,569
